Computers & Internet Logo
Question about The Computers & Internet
94 dodge ram 2500 5.9 gas , I've replaced the relay and fuse to my cruise control but it won't come on ,any ideas ?
I've tried everything to get it to come on just no luck ..
Posted by Kevin Culberson on
2000 Dodge ram 1500 el tablero y las luces traseras no encienden (In English: 2000 Dodge ram 1500 dash and taillights won't turn on)
In a North American website that only speaks English, you choose Spanish! :>D
2000 dodge ram 1500 dash and taillights won't turn on
https://translate.google.ca/?sl=auto&tl=en&text=2000%20dodge%20ram%201500%20el%20tablero%20y%20las%20luces%20traseras%20no%20encienden&op=translate
El Fuso box
Fuse Box Diagram Dodge Ram 1500 / 2500 / 3500 (1994-2001)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
1998, 1999, 2000, 2001 - Here you will find fuse box diagrams of Dodge Ram Pickup 1500/2500/3500 1994, 1995, 1996, 1997, 1998, 1999, 2000 and 2001, get ...
My 1999 Dodge Ram 1500 cruise control will not turn on. I've checked the fuses in the fuse box on the side of the dash but they were all good. Another issue i have occasionally is the brake light
Probably neither.
The brake light switch could knock out the cruise.
You might check the computer for trouble codes, but you'll probably need a shop manual to get the test procedures for the cruise control.
1998 Dodge Ram 1500 2wd cruise control quit working. Cruise light still comes on but nothing happens. I can not locate any fuses for cruise control can anyone tell me where the fuse would be?
In the front, there should be a bulbous looking device - this is the vacuum chamber for the cruise. Check to make sure the vacuum hose did not slip off. That was the problem on my van.
1helpful
Where is my fuse box located 2004 2500 dodge ram gas
Under the hood, drivers side near the battery. Has a knob ontop to unscrew to exposes the fuses and relays. Also should have a plastic fuse puller in there to help get the fuses out.
1helpful
My cruise control will not work at all. It just
Replace fuse & check for corrosion/moisture in fuse box
2answers
1999 Dodge Ram 2500 Diesel 4x4
there is a cruise control module , easiest way to find it is follow 2nd throttle cable under hood right to it. it most cases there unplugged
2answers
O3 dodge 2500d not shfting to overdrive
had the same problem except cruse control wouldn't work either. after checking all the relays and fuses the problem turned out to be moisture in the ECM plugs.
Top The Computers & Internet Experts
NADARK
NADARK
A Kisling
A Kisling
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
