Question about Yamaha Audio Players & Recorders
Problem center 5.1 yamaha rx-v1000
Those of you who have a yamaha rxv1000 it is normal that you have to activate both the words dolby digital dolby d and dolby digital on the screen both in to hear the central When only one text is active, the center speaker is not heard
Posted by Zenax on
2answers
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
I have a Yamaha av receiver RX-V1000 and want to hook up Peavey PV– 115 speakers to it an don't know how
They are 8 ohms which is fine but that receiver doesn't have enough watts to push them. They are 400 watt min 800 watt max
1helpful
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
1helpful
I have a RX-V1000 Yamaha Receiver. I recently added on speakers for my back yard, but would like to run them independent of the receiver. Meaning I don't want to have to have speakers in the house on...
Any Tape Out (REC) is flat Line Level output for any analog source selected by the RX-V1000.
Or you could just set up Zone 2 as on Page 61 in the manual - with or without the remote capability.
When i play dvds through my rx-v1000 the pro logic light is always on. shouldnt it be decoding a digital signal when im playing a dvd?
Hello,there is a chance that dolby digital isnt turned on on the dvd players audio settings, make sure in the dvd menu its not set to pcm.
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
I have a PS3 hooked up via HDMI to my Yamaha RX-V465.When I play a blueray disc the signal info shows PCM.Shouldn't it show Dolby Digital or True HD?
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
How much is the price of the micro processor for Yamaha rx-v1000 receiver?
I personally would not tackle this. Try the Yamaha dealership, perhaps they can help.
No Sound From My Center Speaker
on the yamaha amps you can do a speaker test to see if all the channels are working. once that is complete and working you should check the disc to see if it is true digital or dolby pro-logic. normally on the disc menu you can select this.
2helpful
Yamaha rv1000
ok yu problem has to be with the protection system before you burn it up it collapses to protect the whole system.....go direc to the thermal cut off devices on the main output and then to the power system......
Open Questions:
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
