Televison & Video Logo
T
Thanh Bui Posted on Aug 10, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change to QLED main board
I have a Samsung 82''tv UN82TU700DFZXA IF is possible changing main board to QLED main board? Thank
Larry
Level 3:
  • Samsung Master 5,042 Answers
  • Posted on Aug 10, 2022
Larry
Samsung Master
Level 3:
Answers
5042
Questions
Helped
1239524
Points
18413
NO...It will not work
I have a Samsung QLED Q60R Television. How can I change where my local news and weather come out of?
Question edited for clarity, spelling and remove abbreviations.
Question moved from Motorcycles category.
It has a feature called 'Ambient Mode'. You would better off having the Weather Network App on the television and on your Smart Phone and set it for Notifications. The App is free.
The TV app is available for download on Roku, Apple TV, FireTV Stick, Amazon FireTV, AndroidTV, Panasonic, Sharp, Sony, Samsung, Philips, LG, Huawei, and through most other Smart TV and Streaming devices.
The Weather Network, M?t?oM?dia TV Apps - FAQ
Use Ambient Mode on your Samsung TV
Samsung https://www.samsung.com > answer > ANS00082422
You can display d?cor, weather info, news, photos, and artwork. You can even ... Press the Down directional button to change these settings: Color and Theme ...
Samsung https://www.samsung.com > answer > ANS00088842
With Ambient Mode, you can display a variety of content on your TV screen, including images, artwork, weather updates, news headlines, and even music. To use ...
It is a nice set!
https://www.samsung.com/us/televisions-home-theater/tvs/qled-4k-tvs/65-class-q60-qled-smart-4k-uhd-tv-2019-qn65q60rafxza/
1helpful
Samsung TV PN63B590T5F will not change volume or channels with the remote or using the buttons on the TV. Main logic board? Power board? Something else?
It's either a main board issue or an issue with the button panel, I'd unhook the button panel and see if it works with the remote, if you can change things then it's in the buttons, I didn't pull up service info so it's possible the infrared and buttons are all one unit, in that case it will be harder to diagnose the issue
2answers
Samsung QLED Sound/No Picture/powering on/off
These units drive the LED to its limits and when the LED back light strips fail the problems start. The trouble is finding out if it is the LED strips or the power supply. This is not something that is easy to do. You need to have space to work on it and that usually is a large room to lay is down on. Then you need to take it apart and that involves using spudgers to separate the clamshell construction housing. Once you get it apart you can then start to troubleshoot the issue and see if it is the back light strips or the power supply. Some people just opt to order the power board and some times this works. Other times it does not. If you are going to test the strips then you need an LED tester and the process is tedious. Either way you go it likely to cost you about `100USD to get parts.
Samsung Qled tv has dark bands should replacing the led strips fix this problem?
It may but there are a lot of other things that could cause this from a board issue to connectors not making good contact
1helpful
I have a Samsung QLED QN55Q60RAF tv that constantly reboots. It shows the Samsung logo, then for a second it shows a program, then it goes black over and over.
Sounds like Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Will be best to consult the authorized service center.
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
How do i fix a Samsung LCD TV mod. LN46B650T1FXZA that was not turing on
The T-Con board would have been the first board to look at . It controls the whole picture.
Samsung hp-r4262 black screen
your y main or x main is dead or y buffer board
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
