Re: Canon c3835i error code 000a0b no paper jam but they...
Hi
1 has printer room humidity increased ?
2 was paper stored in a more humid room ( can absorb in a few seconds ?
3 was aither in 1 or 2 in humidity above 65 %?
The Canon imageRUNNER ADVANCE DX C3835i error code E000202-0010 indicates a problem with the fixing film rotation. Here's some information about the potential causes and steps you can take to address the issue:
Fixing Film: The fixing film is a component within the fixing assembly responsible for transferring heat to the paper during the printing process. It's possible that the fixing film has become damaged, worn out, or needs replacement. Inspect the fixing film for any visible signs of damage, such as tears or wear. If necessary, contact Canon customer support or a qualified technician for assistance with replacing the fixing film.
Fixing Assembly: The error code can also be caused by a malfunction in the fixing assembly itself. The fixing assembly consists of various components, including the fixing film, upper roller, lower roller, and temperature sensors. If there is a problem with any of these components, it can trigger the E000202-0010 error code. In such cases, it is recommended to contact Canon customer support or a qualified technician for further diagnosis and repair.
Power Cycle: Sometimes, a simple power cycle can help resolve temporary issues. Turn off the printer, unplug it from the power source, and wait for a few minutes. Then, plug it back in and power it on again to see if the error clears. If the error persists after the power cycle, further troubleshooting or repair steps may be necessary.
It's important to note that the E000202-0010 error code is specific to Canon imageRUNNER ADVANCE printers, and the exact steps or recommendations may vary depending on the specific model and configuration of your printer. Consult the printer's user manual or contact Canon's customer support for more accurate and detailed instructions tailored to your specific printer model.
If your Canon IR 2520 copier is showing a "paper jam" error message when powering on, but there is no paper in the fuser, it could be caused by a few different things:
A sensor problem: The copier may have a malfunctioning sensor that incorrectly detects a paper jam in the fuser. This sensor might need to be cleaned or replaced.
Wiring issue: There may be a problem with the wiring that connects the sensor to the main circuit board. A broken wire or loose connection could be causing the sensor to malfunction.
Software issue: The copier's software may have a bug causing it to display the "paper jam" error message even when there is no paper in the fuser.
Mechanical problem: The fuser assembly may have a mechanical issue, such as a jammed gear or roller preventing the copier from correctly sensing that there is no paper in the fuser.
It is best to have a professional technician diagnose the issue. They will be able to identify the specific cause of the problem and make the necessary repairs.
It's also important to check the owner's manual for troubleshooting options or error codes that might be displayed on the copier.
If the copier is still under warranty, it is recommended to contact the manufacturer for service.
With commercial machine like the ImageRunner, it is often staff roughly removing the jammed paper and leaving a tiny piece of torn paper over one of the sensors.
Remove the wall mains plug. Remove all the paper trays. remove the toner cartridge, open all the side doors and look carefully with a flashlight for a small piece of paper.
https://oip.manual.canon > ... > Problem Solving
Follow the instructions on the screen to clear the paper jam. The screen is displayed repeatedly until the paper jam is cleared. If you press [Close], you can ...
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
keri is a FFRAUDD !!!!!
