Televison & Video Logo
Question about Magnavox Televison & Video
I have a Magnavox DVD Player/Recorder MWR10D6 that plays DVDs and CDs perfectly that I just got but won't play any blank CDs so I can record. How do I fix this?
Steve Pack
  • Magnavox Master
  • 6,215 Answers
Posted on Aug 10, 2022
Testimonial: "Thanks. Had no idea it couldn’t record on CDs"
Cannot play recorded movies on another dvd player
some dvd recorders only record to be play on their own machine...
and the ones that can be play on other machines (that player must be updated as in new model) i had to buy new machine to play my toshiba dvds this also works out you borrow dvd now and record it also
Burner on DVD Recorder; it neither records nor plays DVDs
through experience, bring to a tech nearest you.its either the lens or the mainboard or mpeg is faulty.
1helpful
DVDs from DVR don't play on any other DVD player
yes when you have finished the recording and preferably when the disc is full the disc must be finalised to be compatible with other players but be aware if you finalise a disc you cannot record on it anymore
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
1helpful
Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... www.funai-corp.com/support and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
MWR10D6
i cant record with my
MWR10D6
since i bought it I dont know what is the problem. I used all the correct conection.
Magnovox Dvd Recorder closing out disk
Put the disc back into the recorder.
Goto the setup menu.
Select Disc Edit. Press OK
Select Finalise. Press OK
Your DVD player is made by Funai (for future reference)
The User manual can be downloaded HERE. You need page 38.
MAGNAVOX MWR10D6
You need to finalise the disc before it will play in a DVD player (DVD+-R), or make edits compatible (DVD+-RW)
Check out the "Playing the discs in other DVD players" section in the "Recording" chapter of the manual. (Page 36)
If you don't have the manual, it can be downloaded from this link
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
