Computers & Internet Logo
Question about Red Computers & Internet
My Nebo recline 1500 won't charge
I've tried different cords and nothing. Yes lights red and green are working.
Posted by Brandy Knotts on
Solomon Admin
    Habit-Forming:
  • 50 Answers
Go here if it do not work then sorry https://www.youtube.com/watch?v=gAxF-O37J8c
thx for join FIXYA! and being a member :)
Posted on Aug 23, 2022
Can you use any 18650 battery for Nebo slide King
If the size and voltage is correct yes but do not over charge to more than 3.7volts or let the battery voltage go lower than 2.7volts!
Nepo Redline Blast RC Rechargeable Waterproof Flashlight. Where can I get the circuit board for it please.
Question edited for clarity, full 'make model (what it is)'. 'Waisted', the area around a female's middle. 'Wasted', wrecked.
Question moved from Television and Video.
Go direct to the maker for a warranty repair.
Contact nebo
https://nebo.acgbrands.com > en_US > contact
Contact nebo. How can we help you? Questions / Comments. Questions / Comments Warranty Claim Warranty Registration Return Track Order ...
My Nebo won't charge
Are you in Lock Out Mode? Or do you have a problem with the charging lights, red and green?
https://www.nebotools.com/product_images/8976694UserManual.pdf
2answers
What does it mean when bcs1 battery charger light is red
sounds like the batteries that you are trying to charge are caput, if it stays red they are not charging if it flashes red its charging if its green they are charged, some chargers work different so check your instructions.
Helicage work for 15 minute and now the green light does not come on to charge but the red light does and it won't do nothing at all
check that you are trying to charge the right batteries for the charger. Alkaline batteries will not charge and nic hydroxide need a special charger. Every possibility you got alkaline batteries to start with. make sure your batteries are rechargeable.
2helpful
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Archos 70 won't turn on
I have the 8gig Archos 70, the whole thing froze as described in other posts. The solution is not for the feint of heart though. Mine would do absolutely nothing. So what the heck, I opened it up (nothing to lose at this point). Messed about a bit. Read that when it "Bricks" like this there is nothing that can be done. If it is Bricked, something locks it in the memory and function. As long as the battery is connected, it will remain that way no matter what.
Solution. Cut the black power wire from the battery (there are three long wires red white and black), leave for 20 minute, and solder the wire back together and heat shrink the joint. Reassemble, plug in power cord and it should reboot...
My archos is about 3-4 years old, and is mounted to the wall in my kitchen for use as an internet radio
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Top Red Computers & Internet Experts
Marvin
Marvin
john h
matt
matt
Are you a Red Computer and Internet Expert? Answer questions, earn points and help others
