Question about Marantz Audio Players & Recorders
Marantz Cassette Player only fast-forwards or rewinds
My marantz sd451 cassette player will only fast-forward or rewind. Won't play, when press play it is still going too fast and no sound. Also have a marantz tuner that does not turn on but shows it has powe when the memory button is pressed. Any help greatly appreciated
Posted by Sally Davis on
1helpful
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
My car cassette player is stuck on fast forward
Buy a cd player or hit stop or rewind button , if electric button , clean if physical mechanical button check for jams
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
1helpful
4answers
Play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
2answers
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
