Re: Mobicel doesn't read sim card and only works when on...
It could be that the battery might be faulty or there is a problem with your cell phones SIM card and the SIM card might be need to be replaced or your cell phone could be broken and it needs to be fixed.
Depending on the Phones Make and Model and what type of SIM card you are NEEDING if SIM card didn't come with PH?
You can go online and look at diagrams of the Various SIM cards. Most SIM card fit Behind the Battery of your Smart PH. You must carefully remove back of ph most smart phone have a small indention to assist with removal? If not either use your nail or THIN OBJECT (Fake Nail Tips Work Great, Even your Nail, plastic/Wood Tooth Pick or any thin enough non metal to open seal ) Then carefully remove back of ph then Battery the SIM card slot will either be on the side or Top or bottom behind Battery space Slide Sim card in with Metal connector sides down in direction indicated then replace battery and back of ph. Some Phone come with a Internal SIM Card for Programing of phone, the other SIM card Slot is for Memory make sure if this is what is NOT Situation your PH? Some even have Duel SIM Slot they Usually can be programed with either type of SIM Card Purchased these are for the new I call Free-agent Phone meaning you Purchase your Phone and Choose your Carrier Such as Straight Talk ect.
Hi, first check whether the card is inserted correctly, if that is right, secondly check if the card reader pins are in place, thrid try a different sim card, fouth, ask the previous owner to insert his her sim card and see what happens.
If all else fails, please seek a phone specialist as ypou mentioned above, its a 2nd hand phone.
3 unsuccessful tries locks the sim card,this is due the security code which you enabled for SIM card , you can still use it buy purchasing another sim card through the service provider that the phone was used with. Slip in the new sim card and it should work
1. Is there a SIM card in the phone? Is the SIM card from the same carrier/provider you got the phone from? Was the phone purchased as part of a plan or separately?
2. I see the not charging message a lot with my v551 that I had. I usually adjusted the inserted connector (after insertion) and 85% of the time, the phone recognized the power coming through.
If this fails, then try another power adapter. If after trying a new power adapter does not work, then the pins on the phone has sustained some damage.
Hope this helps :) Kindly leave a rating. Thanks..
