I bought a second hand blackweb home theater system bwa18s8003 that has only the receiver and subwoofer how can I use this without the speakers
I bought a second hand blackweb home theater system bwa18s8003. I am not familiar with speakers and these home theater systems. I thought a subwoofer was a speaker but after getting this home and doing research I see now that there should have been five little speakers making this like a surround sound I suppose. My friend thought it was a home stereo and for $10 I thought I found a heck of a deal. After reading I see that it's not recommended to switch up brands with this kind of systems. I hope I still have a deal. I'm wondering what kind of speakers (this is BT) I need and if second hand speakers possibly bought at thrift store, that aren't Bluetooth or blackweb brand may work. If not does anyone know a cheap place to get the right speakers, if they do indeed have to be replacements only to this system. My hopes was I have a little Bluetooth setup to play music off my phone and a stereo. I am asking for options as to what I can do with this system, being just the receiver and subwoofer without having to spend much more if any more money. For example, can I just plug it to my TV, etc. How can I even check to see if the two parts work before I put time and more cash into it since a subwoofer isn't a speaker how do I know if I can't the sound? I just guidance all around, wondering if I got a deal or do I need to kiss that money bye, and recycle or toss it. Thank you in advance for any directions and/or ideas.
Re: I bought a second hand blackweb home theater system...
A subwoofer is worth quite a bit of money they go from $100 up depending the output .Asubwoofer is a complete amplifier or woofer that can play low-pitched sound frequencies called sub-bass and bass. It has a normal frequency range of 20 to 200 Hz for consumer items, less than 100 Hz for specialized live sound, and less than 80 Hz in a THX-approved system.
Unfortunately, I don't think you can connect this sub-woofer without the rest of the components of the HTS3440/37 DVD Home Theater System or a related Philips home theater system. The speakers in the system are hard-wired with a colored plug that you connect to the sub-woofer. Then you need connect the inter-connect cable between the sub-woofer to the DVD Player of the system. See the wiring guide in the Quick Start Manual or the User Guide available on the product support page: https://www.usa.philips.com/c-p/HTS3440_37/divx-ultra/support .
Even if you find another Philips Home Theater system that is missing the sub-woofer, I wouldn't rule out a change in the pin arrangement for the inter-connect cable that would cause the system to fail. I can't find any sources for a replacement inter-connect cable; the part number isn't in the manual that I can find.
Evidently this system is a speaker system that hooks up to 5.1 home theater receiver. I've included a few quote on how to hook up the 6050 system:
" Measure and cut wires running from the speakers to the receivers"
Read more: http://www.ehow.com/how_10058195_hook-up-olin-ross-or6050.html#ixzz33bqoGyyY
"Run the wires from all speakers and the subwoofer to the back of the receiver".. The key is to have a home theater receiver, then you can hook up the TV to the receiver.
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores. 2 RCA subwoofer cables 2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
There are several settings on the receiver which can affect speaker enabling. These include speaker levels, ambience settings, balance, & fade controls. Run through the various menu commands & settings, & see if you can find one that affects the problem. If this does not solve the issue, & you have double checked your wiring, then the receiver is likely faulty & should be returned under warranty.
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs. Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
