Computers & Internet Logo
Question about The Computers & Internet
How do I remove the oven fan blade from motor for a Defy 424 thermofan stove and oven? Any pictures, videos or diagrams that can help?
From the front side of the oven
Posted by Asghar Ali Hassim on
  • Asghar Ali Hassim Aug 13, 2022
    This is what the fan blade looks like after removing the nut but the blade itself still can't be removed, this is the original Defy 424 thermofan oven fan motor in question. Any idea how to remove the blade as the round covering is part of the frame?
NADARK
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 79 Answers
1. open the oven and dislocate the door locks.
2. remove the inner cover of the fan section.
3. disassemble the element and unscrew the fan blade nut/screw.
4. open the back cover to remove the fan motor.
5. replace and assemble with genuine parts.
thanks
Posted on Aug 13, 2022
2answers
I have a Defy 731-T thermofan stove the fan switch off during baking is that normal? Are't it supose to work throughout the baking proses
the fan will switch off when with the element when it has reached the right temperature,also n some ovens the fan switches off when the oven door is opened
Jul 13, 2018 • Ovens
1helpful
Thermofan of a defy 731T that keep on burning .
check that the motor shaft is free running as the front bearing could be seizing from oven heat
if it is good , replace the fan motor
Dec 09, 2015 • Ovens
My Defy Gemini Gourmet Multifunction bottom oven does not work. Where is the fuses positioned on this stove, or what can be the problem. The fan is working, so the problem must be with the element or a...
Hi guys. Does the Defy Gemini multifuction thermofan oven have a bi-metallic thermal switch? My oven completely switches off around 180 degrees celcius, then resets itself. I dont see a thermal cut-out, so left with the thermostat or timer PCB maybe?
Jan 22, 2011 • Ovens
2helpful
MY DEFY 731T THERMOFAN OVEN MAKES A BIG NOISE WHEN I SWITCH IT ON. IT SOUNDS LIKE THE FAN. WHAT MUST I DO? PLEASE HELP
yes check that the fan mounting is ok and that the fan blade is tight in place, you can tightenthe mountig screws and the fan blade persist. if it persist then check that the motor bearing
Aug 06, 2010 • Ovens
9helpful
3answers
Defy thermofan flashing 0.00 and auto. I've tried pressing key 4
Hi
Can somebody please help
Thanks Terry
Jun 01, 2010 • Ovens
Top The Computers & Internet Experts
NADARK
NADARK
A Kisling
A Kisling
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
