Cameras Logo
Question about Canon Cameras
My CANON 540 HS have a problem, while pressing the power button, the green light will blink then the screen is black and it's shutdown itself, what suppose to be the problem
I charge the battery, I dnt know of the battery is good or no, i have Canon SX 540 hs
My canon ir 5180 blinks only d green light but d screen does not open
Start with the printer OFF:
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
0 - green - Pressing power button will turn off printer
1 - orange - Service Test Print
2 - green - EEPROM Information Print
3 - orange - Initialize EEprom data
4 - green - Reset Waste ink Counter
5 - orange - Mode to set Destination code
(1: Overseas, 2: Domestic)
6 - green - Refresh printhead (cleaning mode)
I assume the printhead is cleaning and you need to wait for it to finish cleaning. That could take over a minute and a half; I don't know what that delay is for your printer.
If that is not the issue, you may have to reset the printer. This may be possible as follows:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn't power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Release the buttons and simply power it back on. (If you unplug it without powering it down, you may get an improper shutdown error message. If so, click OK on the printer.)
If you are looking at a blank computer screen after all of this, you might try uninstalling and reinstalling the driver.
If this does not fix the problem, you better look into troubleshooting on the manufacturer's site for help for your particular printer.
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
2helpful
Canon i9900 printer. Yellow light remains on. Does not blink. Green light will not come on. Anyone know what part needs to be replaced?
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Black ink ran out and printed one photocopy without producing any black. Change the cartridge several times BUT still does samme thing - no printing in black. Colour is fine, just no black despite changing...
Canon IP 2000 / reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
All the best Pineworks
I refilled my canon pixma ip3000 black ink cartridge and now the black will not print. Can you help?
Canon 3000 INK counter reset
1. Turn off printer
3helpful
Canon Pixma iP2000 wont print black ink?
1. Turn off printer
1helpful
Error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
No black ink
Canon S330 Turn off printer
Press the Power button and the printer should turn off, if not, press the Power button once more.
Printer will not respond
1helpful
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
