Car Audio & Video Logo
Question about Ford Car Audio & Video
1999 Ford Taurus stereo wiring diagram
I've looked all of them up and not one of them has the color wires that I have. This is the list of color wires I have. Red white stripe, two blacks, light blue with pink stripe, tan, black with green stripe and green with black stripe, light blue with black stripe, black with violet stripe, gray with red stripe, red with yellow stripe, dark blue with orange stripe, dark green with Violet stripe, brown with green stripe, white with pink stripe, dark blue and with white stripe and gray. So out of a 20 pin I have 17. It's a 99 Ford Taurus LX just radio no cassette player no CD player need help please
Posted by James kjeseth on
5 Related Answers
Anonymous
  • 11896 Answers
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Posted on Jan 17, 2009
Anonymous
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
ourhowse
Dar
  • 2007 Answers
SOURCE: I have a pre fab wiring harness on my trailer with
I assume you only want lights, brake lights and signals. Your best bet is to plug a wire onto your truck... the flat plug, and turn , first the left signal, on. Use a test light to see which part of the plug in is flashing. Once you have established that, just keep plugging the other end of the wire into the trailer plug, until you get the left turn signal flashing on the trailer. Then repeat the process for lights etc.
You can also take the plug-in apart on the trailer. Inside the plug in it will have l/t, r/t, s, etc. (left turn, right turn, stop, etc.) There will be a very small arrow pointing to the terminal connection that is for each.
Posted on Nov 03, 2009
Testimonial: "Thanks, that should be an easy and sure way."
Anonymous
  • 118 Answers
SOURCE: I have broken wire harness on the back of my Heater/AC automatic climate control. The black harness on the back has 11 different colored wires. Do you know which color wires go on which pins in the ba
Check the dealer to see if they have a pig tail to wire in. if so the new pigtail should have same wire color for matching up.
Posted on Jun 14, 2012
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: trying to match my aftermarket radio with factory speaker wires.. BROWN YELLOW GREEN VIOLET / WHITE STRIPE LT BLUE LT BLUE / BLACK STRIPE WHITE /RED STRIPE WHITE / RED STRIPE
Greg, Check the attached links,instruction and guides stereo and speaker wiring, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WIRE COLOR CODES FOR CAR INSTALLATION
Car Stereo Wiring Diagrams and Car Radio Wiring Diagrams
https://www.installdr.com/quickwiring.asp
Car Stereo Wiring Diagrams Director
Posted on Apr 03, 2016
2answers
I need the color codes for the radio on a 2002 ford traurs.
Color code for radio i dont understand that one
2helpful
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
2helpful
3answers
Car audio wiring color codes.for 1988 ford f150 truck
Thanks for using FixYa.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
I need a radio diagram for a 2000 ford taurus so I am able to hook the right colors together.
Go buy a wiring kit from autozone or walmart....Just look up your year of car and it clicks right into your factory wiring...Then all you have to do is color code your wires fromm the stereo that you're putting in.
2helpful
Need diagram of audio system
2006 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black or Black/Yellow
Car Radio Illumination Wire: Dark Blue/White
Car Stereo Amplifier Location: Drivers side shock tower in trunk on sedan’s or station wagon behind spare tire.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
pls rate
4helpful
2answers
2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: N/A
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
4helpful
2answers
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Top Ford Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Ford Car Audio and Video Expert? Answer questions, earn points and help others
