Cameras Logo
Question about Cameras
SB-900 underexposing x 3 stops
D-90 with SB-900. Had worked fine a few months ago. Today it is underexposing about 3 or 4 stops. Possible a grandkid found a setting. I tried different modes, new batteries, am using TTL D-90 exposes correctly without flash attached
Posted by Jptort on
2009 dodge avenger many problems
That light is to let you know there is an issue with the Throttle system and there is reduced power. Check for codes with a real scan tool, not a code reader.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Hello, I have a Samsung DLP HLR5667 and it blew a lamp 4 months ago, I replaced the lamp and it worked fine for about 2 months and started shutting off after only running for about 90 seconds. I reset the...
You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Car over heating also
check your fins on the radiator and your water pump also check the thermostat
My 2000 Durango 4.7 liter V8 starts fine, runs fine, but dies when it comes to a stop. I had my software and module redone 3 months ago and about 2 weeks ago it started shifting slow and hard. Then today...
Could be a bad catalytic converter. Have the exhaust back pressure checked. Check the fuel pressure & if possible,drive with the gauge on & see what happens when it dies. If the pressure is good,then it's not fuel. Write back if you have more issues.
2answers
NO DISC message
I assume that problem is dirt on laser lenses. If you don’t get any result after this, than you can replace receiver with new one. If you want to use your existing speakers with new receiver with integrated amplifier, you must pay attention on wattage, to be same like old one (i.e. 100W), and also resistance (i.e. 4 ohm). If it’s same like old receiver, you should have no problem. Good luck.
NO DISC message
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
