Question about Heidelberg Office Equipment & Supplies
I need a Heidelberg MO offset two color printing press, electric drawing please?
Posted by Chabala kataso on
ADMIN Andrew
    Top Expert:
  • Heidelberg Master
  • 57,474 Answers
1helpful
I need heidelberg gto 46 electrical drawings
There's a website that has all this information about all this and manuals everything totally fr ee there are many actually but I personally like few .. let me know if u need help
thanks
Blurred printing at the x offset
Print head is not aligned properly . You need to adjust heating plate on head.
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
1helpful
Need rear panel drawing or install instr for Heidelberg CD51
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
The prints show horizontal lines offset.
Do you have a copy of a drawing and a photo of the resultant print that you can send to me at [email protected] as there could be several reasons for this. Also what software are you using on the iMac?
2answers
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Top Heidelberg Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
