Sewing Machines Logo
Question about PfaFF Sewing Machines
Pfaff 2048 presser foot lifter does not raise or lower the presser foot. the presser foot is stuck in the raised position
In fact, the lifter lever is loose.
Posted by philmollicon on
My feed dog will not go back up with leaver in back
Are you talking about the presser foot lever? That lever raises and lowers the presser foot. If you are talking about the feed dogs, there is usually a lever to raise and lower the feed dogs. Consult your owner's manual.
Error message on Pfaff 7570 is "bring presser foot lifter to sewing position?" Is this a fatal error or is this a procedure that has to be done before the machine will operate?
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
The manual for the Pfaff Creative 7570 is available on the product page: http://www.pfaff.com/en-US/Machines/creative-7570 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_7570-manual-EN.pdf?ext=.pdf . See page 32 (page 36 of the PDF) of the manual to see a picture of the presser foot lifter.
I hope this helps.
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
The presser foot won't go down.
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
17helpful
2answers
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
2helpful
3answers
How do I remove the face plates on a Pfaff creative 1475 cd sewing machine so I can get inside to find out why the presser foot lifter is not working properly. It will raise up but it goes down slowly (not...
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
1helpful
Machine has seized
Lower the presser foot lever. This machine winds the bobbin when the lever is raised to it's highest position and it locks the rest of the machine. If that isn't the problem, then you probably have a thread lock,which is a piece of thread stuck in the hook assembly. This can be removed by rocking the hand wheel back and forth until it is free.Be sure and oil the machine before you use it since it has been sitting for so long.
sewman7
Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
1helpful
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
