Question about Yamaha Audio Players & Recorders
Yamaha Amplifier AS 301, AS 501 intermittently shut off
ADMIN Andrew
    Top Expert:
  • Yamaha Master
  • 52,944 Answers
Nearly always due to overheating. Remove the case and vacuum all the lint out. Clean any vents at the rear.
Posted on Aug 02, 2022
Testimonial: "No over heating. Sometime the problem occur in few minutes on. tks"
Larry Ng
    Top Expert:
  • Yamaha Master
  • 11,183 Answers
2021 amp, has new TRICKS , add STANDBY.
4 causes,(more really) in the manual
1: speaker wire shorts or even speaker.
2: overheating of final PA power amp out. vents blocked. or lint.
3: a bad amp,(inside)
run the amp, on desk not a cabinet and cool 20F room,
no cables connected by AC power.
4: so does same thing at 8 hours unused it goes to STAND BY MODE. (2021 amp, now do this trick (wow)
does it still fail, this 1 test. do tell.
I have 40 year old amps here 100watt RMS out.
that self shut off for speaker short or too hot.
nothing at all new about that and do not need a processor to do that ever.(facts)!
what matters are the new 2021 tricks inside.
it does say turn the volume down to stop amp overheating. or let it cool in the manual
or power surged
or Impedance switch set wrong
the Power LED dims so show standby
Testimonial: "Everything looks normal no error at the indicator. No overheating, no open/short circuit and might occurred wihin few minutes. The amplifies has microcontroller to detect any abnormality . Googiling indicated the similar clicking relay problem occurred on similar model with random turn on. In my case is random turn off (turn to standby). Thanks"
  • Larry Ng
    Larry Ng Aug 04, 2022
    read the manual about that. it goes to stand by because it sees (detects) the amp being unused.
    not playing music etc.
    so it did not really shut off, (cut sound) it just went to sleep like a PC, (Energy Star like (laws etc)
    Yamaha Amplifier AS 301, AS 501 YOU HAVE 2 AMPS? OR 1.??
    I am reading your manual to you.
    page one tells,
    Even when the [A] (Standby/On) switch is turned off, a small amount of current still flows through this product.
    Save power by using AUTO POWER STANDBY switch (see page 4)
    Dim power lamp Dimly lit,
    This unit is in “standby” mode.
    For details on the “standby” mode, see page 6.https://manuals.plus/yamaha/a-s701a-s301...
    page9
    The unit enters standby mode automatically if not operated for 8 hours.
    If A AMP on the remote control is pressed while the A (power) switch on the front panel is in the on position, this unit enters standby mode. Press A AMP again to turn this unit on.
    trouble page, goes off suddenly word.
    Confirm that there are no other issues causing this problem, and then turn this unit on again.
    To turn off the AUTO POWER STANDBY function, set the AUTO POWER STANDBY switch to OFF on the rear panel.
    full stop, the manual goes on and on about standby,
    found all this in under 1minute reading the manual to you
    RTM.
    2021, the brave new world.
  • Anonymous Aug 05, 2022
    Thanks.
1helpful
Yamaha HTR-6240 shut down when it opens with click sounds
You will find it has a power amplifier issue. Take it to an authorised Yamaha repair centre.
My HTR Yamaha 5860 shuts off as soon as I turn it on.
I have seen several things that can cause this. One is a capacitor that holds the memory in the cpu. Another is a voltage regulator and then there are failures in the final amplifier transistors
Yamaha amplifier rx-v457 auto shot down.?
If the auto shut down is activated the moment the amplifier is turned on then there must be a problem with the output. Please check the speaker cables visually for short circuit. You can also use a multi-tester set at 20 ohms scale. Unplug the all the speaker cables from the amplifier and test at the cable terminals. You should get a reading anywhere between 4 and 10 ohms at each terminal.
If the speaker.cables are fine then the one of the power outputs of the amplifier (front or central or surround) must be damaged.
If the shut-down occurs while playing music for some time, you may have to remove the cover of the amplifier and check for dust accumulated on the heat sinks of the power output stages (aluminium plates with fins). Blow the dust off the sinks and the rest of the circuits.
Intermittent sound Yamaha RX-V675 amplifier.
Loose wire, maybe power or remote on. Some vehicles have their own amp, which could have a problem. Could be a bad ground. Check wiring and connections.
When playing the DVD when you turn up the volume the amplifier turns off.
Amplifier and an over load issue and is shutting down to protect the circuits. Needs to be checked out by tech.
1helpful
Intermittent drop out on Yamaha CA amplifier
The output speaker relay is corroded a bit. The higher volume creates enough voltage to bridge the gap and make a good connection again. Some of these relays are sealed and can not be cleaned. The relay should cost around $10-$15 max.
Dan
Yamaha HTR-5170 amplifier shutting off & not powering up
I agree with Jango. Go back to the setup when it last worked. If adding the DLP is the problem, you may have some sort of a ground loop formed between the TV and the receiver. good luck...Rob
1helpful
R-V1105 Yamaha receiver
Your audio amplifier ICs are damaged,you gotta change it.
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
