Jeep Chrysler/ Dodge/Vw Routan Ves 2 Channel Infra Red Remote Control Logo
Question about Jeep Chrysler/ Dodge/Vw Routan Ves 2 Channel Infra Red Remote Control
VW routan 2009 has no electrical, no fuse
Hi, My Routan was running great. My son was in the car while it was running, with ac on and listening to his phone through the VES auxillary mini-stereo jack. He turned off the ignition, then on again to accessory, then everything went dark. Car has no response whatsoever. I connected a charger to try to start it, and I got a no fuse error. I think a fuse was blown, but don't know where to start. I've located the fuse box, and checked all the M fuses, they look fine. Next is the cartridge J fuses, then relays. Does anyone have any idea of where I might find the right fuse to change? Are there any other fuses that could cause this total blackout? Thanks.
Posted by wfoster99 on
Replace the radiator on a vw routan 2009
Pressure test the system with appropriate tester,use mirrors for inspection,check your warranty status,recalls etc....
How do I check transmission fluid in 2009 VW routan 3.8L V6 engine
Use a standard Chrysler dipstick for the year and engine size. It will not seat because they removed the dipstick but you can check the level with it. They did this to get your money.
Where is the fuse box located in a 2009 Routan?
Usually, as a rule of thumb, there is a fuse panel in the cab of a vehicle, and one under the hood. the one in the cab is in the dash, usually pulled down by a lever or handle, or sometimes even concealed by a plate. the one under the hood is labeled "electrical panel" or something of the like.
Need to change battery in key fab 2009 VW Routan
Crest Lock INC.10015 Pulaski hwy Baltimore Md.4102567800 they will install it for the cos
I just purchased a new remote key for my vw routan 2009 how do i program it
You can programm the new remote key for VW Routan 2009 only using suitable diagnostic equipment connected to the data link connector of the car. I suggest you to go to a VW dealer for this job. Good Luck!
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
