Video Cameras Logo
Question about Sony Video Cameras
SONY CCD-TRV37 cassette compartment buttons doesn't work incluiding the zoom one, can you help me?
Posted by Jesus Adrian aguilar... on
Curt mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 96 Answers
Your Sony is similar to this one. This switch has 3 positions. To playback and use buttons for cassette, turn the dial to VCR or it might be called VTR.
SONY CCD-TRV37 cassette compartment buttons doesn' - image-e4f4ozhsscua0uhqzaix5g5v-d-0.jpg
Posted on Aug 19, 2022
Sony camcorder CCD-TRV37 manuals
The manual for your Sony Handycam CCD-TRV37 can be found on the Sony eSupport website here:
http://esupport.sony.com/perl/model-documents.pl?mdl=CCDTRV37
2answers
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
5helpful
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
3helpful
We own a Sony handy cam model CCD-TRV37 and the tape will not come out. When pressing the eject button a little yellow arrow blinks upward on the screen and a code C:32:20 blinks in the upper right corner....
Error C:32:20 indicates that the take up reel of the cassette that winds the tape into the video cassette is not taking up the tape fast enough thus causing slacking when unloading.
Remove the battery or power cable, connect, and perform operations from the beginning.
if this fails take the camera to a repairman to remove the tape manually.
1helpful
Will this unit play 8 mm cassette tapes that are formatted "mp"?
You want to purchase the Handycam CCD-TRV37? If so that is 8mm. If your referring to another camera give me the model and I will let you know. Though I would consider switching over to mini-dv. The quality is alot better and is the standard now so there are many models available.
Thank you,
Lee
2helpful
2answers
Where is usb connecttion for a CCR-TRV37
CCD-TRV37 is analog Video-8 camcorder and has no USB port / connection. USB port is available only in digital camcorders.
2answers
Sony ccd trv37
amigo, desconecta el cable de alimentación y la bateria. Con la video en "LOOCK", volve a conectar todo, y mantene apretado el "EJECT" y luego de un rato te la abrira. se toma su tiempo porque rebobina la cinta hasta soltarla. espero esto te ayude.suerte
Cassette stuck
If battery is fully charged and unit still will not open, try removing the tape door and see if there is tape wrapped around capstan or ther parts. If you cannot find anything apparent, take unit to qualified pro tech
1helpful
Stopping the Zoom
Usually when this happens, the control itself has failed. Repair requires replacing the entire top operation assembly in which the zoom is contained. I wish that there was another solution, but I have replaced many of these for this problem. If you have an interest in how to obtain the part let me know. Good Luck, magic seadog
PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Open Questions:
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
