What are the differences between green tea and black tea?
Black tea and green tea originate from the same plant; however, they require different processing techniques. The next time you drink tea there are more similarities and differences that you may notice.
Both green and black tea is made from the leaves of the Camellia sinensis plant. The key difference between the two is that black tea is oxidized and green tea isnot. To make black tea, the leaves are first rolled and then exposed to air to trigger the oxidation process.
The term 'Black Beauty' has been well overused by now. It was originally the 1957 black Les Paul Custom model, but by now is any black Les Paul Custom. In addition Gibson themselves are cashing in by doing reissues, finished to look older.
So if it is a black Les Paul Custom, then yes, it is a Black Beauty, according to someone somewhere. On top of that, Gibson has reused serial numbers, in different years for different models.
If the serial number is stamped on the headstock with 'Made In USA' the guitar was made at the Kalamazoo or Nashville Plant, in 1976.
Those guitars are worth US$3000-4000 depending on condition.
Otherwise it was made at the Nashville Plant, TN, on January 11th, 2007.
Those newer reissue guitars sell for similar prices. .
Iced tea is made using citrus fruits such as citrus fruits, limes, lemons and even the berries. This recipe I've made use of charcoal powder. You can also make use of tea leaves. Green tea is also a good option to make the ice tea. Because tea is rich in antioxidants, it's a good idea to incorporate tea into your diet.
I've made use of organic, unrefined cane sugar to sweeten the tea. You can also add jaggery (though the flavor will differ) and any other sugar of your preference. How to make iced Tea recipeSteeping tea 1. In a pan pour 1.25 litres water. 2. Place the pan over an open flame. Let the water get to a boiling point. 3. After the water has come to an end of boiling, turn off the burner and pour in 2 cups of black tea powder. To give a subtle tea taste one can add 1 tablespoon of tea powder. In lieu of powdered tea, you could make use of green or black tea leaves. 4. You can add 1/3-1/2 cup of sugar. For a taste that is less sweet you can add 1/4 cup of sugar. 5. Mix well, and let the tea leaves infuse within the water for 4 five minutes. If you want a milder tea flavor, steep for between 2 and 3 minutes. 6. After the tea has been steeped in the hot water add 3 tablespoons of lemon juice. To give it a more lemony flavor it is possible to include 4 tablespoons lemon juice as well. It is also possible to skip the lemon juice completely and just make simple cold tea. 7. Stir using the spoon 8. Then strain the tea into the glass or stainless steel jar. The glass jar must be able to withstand the temperature. 9. Allow the tea to cool to the room temperature. You can then chill it in the refrigerator. 10. As you serve Add four to five glasses of ice cubes. You can add more or less according to your taste. Additionally, you can add between 1 and 2 slices of lemon. The addition of lemon slices is not required. 11. Pour the tea into the glass. 12. Garnish with slices of lemon or a small sprig of mint leaves. Serve tea with ice immediately. While drinking , stir the tea with an ice cube or stirrer.
you will want to make the following connections
existing-black wall to black dimmer now connects to red dimmer
existing black wall to red dimmer now connects to black dimmer
existing red wall to black dimmer now connects to red dimmer
Green wire connects to bare copper wires in wall
