HS-120B-HL MAKES NO SOUND
BATTERIES ARE CHARGES LATELY BEEN FEEDING BACK WHEN IT CONNECTS, THEN IT WORKS, NOW THERE IS NO SOUND
Posted by RONALD BEAN on
ANAWE NABIL
    Habit-Forming:
  • 44 Answers
It is likely that an issue with the audio settings or hardware is causing the lack of sound. Try checking the audio settings in the operating system and ensure all hardware is connected properly. If this does not work, consider replacing the speakers or headphone jack.
Posted on Jan 18, 2023
Larry Ng
    Top Expert:
  • Audio Player... Master
  • 13,326 Answers
ITS NOT A CAR AT ALL IT IS SPEAKER BY TOA
ASK MAKER FOR SUPPORT
GUESS HERE
EUROPE, NOT TOLD YOU LOCATION .
https://www.toa.eu/products/hs-120b/
2helpful
My Audio headset has worked great-but now...it stopped working
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
Hi have 2009 chevy cruze 1.6 had starting problems..always. Replaced fuel pump, alternater battery. Lately agian starting problems. Just make click sound, doesnt wanna start. Lights up but no starting
Any lights lit on the instrument cluster , SECURITY ? Check engine light ? Check connections at battery an starter ! Have starting system voltage drop tested , possible battery cables or starter ! How to Check Your Starting and Charging System
Does late model chevy vehicles alternator charge a dead battery or does it just maintain it. I pull a trailer will it charge the battery on the trailer?
A four pin trailer wire won't charge it. But the bigger one ( I believe a seven pin/ round connector) will if it is wired right. You would need a 10 gauge wire to feed the B+ side of the trailer battery from the alternator. Also make sure the ground is good.
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
www.gewizrepairs.co.uk
Bulk Charges then goes in to float charge and hangs does not switch back to bulk when batteries voltage drops. Four interstate 6 Volt golf cart batteries installad march of 2013
Sounds like a tough one. What i would do is open the controller, look for bad connections. also clean all wires coming to and from the batteries. Remember that tarnish or invisible oxides make alot of resistance causing a voltage drop and the voltage inaccuracy will not feed the correct readings to the control box.
My c.t.m. hs-2850 is not holding a charge.
Sounds like you might need to replace the batteries. I have included the link for the HS-2850 User Manual PDF Download <Click on this.
2answers
2002 VW Jetta GLI 2.8 V6 All dash Lights came on Battery Dead (new Battery) Pulled Altenator and had tested (tested ok) Altenator belt torn on side, could this cause problem? What could it be?
this does sound like a bad alternator,have the battery tested and check the connection at battery and positive feed cables form battery,next time all the lights come on have the charging system check dont remove alternator,also make sure the power cable to alternator is good,ive had a few of these they get hot and dont charge, have them tested and they tell me its good, put it back on car and customer is back again,i replace the alt and problem solved. hope this helps.ps check the alt fuse.
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
1helpful
Strong Noise on Brother HL-5240
Make sure the end tab in the paper tray is not too tight. The tab where you set the paper length. The paper should have about 1/16 inch space and not hold the paper too tight.
2answers
Pride victory Scooter battery charged won't run
The clicking sound is most likely the motor relay engaging and disengaging. Most scooters and wheelchairs do this when in neutral, or when damaged.
I would first make sure its not in neutral by switching a petal, or lever in the back or at the side of the scooter. (you may need to do this on both sides) You should switch this when the scooter is off because you will need to restart it afterward anyway.
If that doesn't work you most likely have a motor issue if the battery is charged as you describe.
 Grubhead
Grubhead
Marvin
Marvin
