My old sewing machine started going all by itself and now won't stop. I had to pull the plug out to stop it. As soon as I plug it back in it goes without me doing anything. The foot pedal doesn't affect it and can even unplug that and it's still going. Am hoping it's something simple!?? Any advice welcome please.
First, Don't run the machine until you get it repaired. Running it could burn out the actual sewing machine costing you a lot more money in repairs. This problem could be that the mechanism inside the pedal is stuck in the down position. Most sewing machine pedals can be removed. Sit with the back of sewing machine nearest to you, as if your using it from the wrong side. The block connector for the pedal should be next to your left hand. Pull the connector block towards you. It might be tight so may need a reasonable amount of force to get it out. If you take it to a sewing machine specialist they may be able to service or repair it.
