Model EWF 1090 power just stopped working, it was working fine I went to turn it on and no lights at all, have checked power point it works so not a breaker issue please help??
Was told it could be a fuse in the machine, I have no idea where the fuse is located or how to get to it to check?
I have the same problem "no power at all" when plug into the power wall inlet. No lamp on, display is blank/no led of 7 segments lit, nothing. The door can be opened and closed normally. Holding Delay and Extra Rinses buttons when power on the electrolux EWF 1074, doesn't help either. The electricity wall plug in is active. What can I do more ?
I have a similar problem on mine. We suffered a few E20 codes on the preceeding days before the machine went "dead." I assumed an issue with one of the pumps had caused the computer to get cooked. The problem is that I can't find an electrical data sheet inside the machine anywhere. I've been trying to find a service manual online with no luck so far.
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
