Sewing Machines Logo
Question about PfaFF Sewing Machines
PFaff 4862 just quit - What should I look for?
I was sewing - it just quit. Unplugged and replugged, changed to a different outlet, opened and closed the little door - would not start. Waited a while. Would not start. The light does not come on. It did run for a bit, but quit again. Could there be a broken wire in the foot pedal, that door switch, or the on/off switch? Help!!
Posted by V Bedard on
1helpful
I have the 4862 cover lock Pfaff machine and cannot threat the yellow threaded. Spent all morning and now blinded by science.
Just walk away and leave the machine for a few hours or a day. Sometimes frustration just makes it worse (it took me a full day to learn how to thread my first serger!).
Do you have a manual? It has a pretty good diagram on page 15 (compared to most manuals).
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwij-qKqnefZAhXri1QKHQ30BRAQFgg0MAE&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fcoverlock_4862-manual-EN.pdf&usg=AOvVaw0avvmTKBtCaXnCgLEEyauS
Be sure to ALWAYS RAISE the presser foot when threading. Also, ALWAYS thread in the sequence shown or you will most likely never get the machine to work properly. The red thread first, then the yellow thread.
If you continue to have problems, I'd suggest going to your local Pfaff dealer and asking them to show you how to thread it.
My Pfaff synchrotronic 1229 will not pick up the bobbin thread. It was sewing fine, I stopped to put in new bobbin and now it wont pick the thread up! Grrrrr...
Um, quite possibly something to do with the bobbin you installed. Check that it was loaded correctly. You might also try a different bobbin and different thread--could be something defective with that particular bobbin. Try a brand new needle, just in case. If still issues, then may consider taking it for service.
I have a pfaff coverlock 4862 serger and the power which is triggered by the folding door in the front of it keeps shutting off. What sould I check?
There is a safety switch activated by the front door that apparently is not being fully de-activated. Perhaps the door is not straight or not completely closing.
I need to know how to wind a bob in for Pfaff 2036 machine. I would also like to obtain a copy of the instruction manual for this machine
How about this?
Threading Pfaff Sewing Machine mov
PFAFF expression 2034 Instruction Manual
(this is for a 2034 but is probably close enough to your machine to be useful. Usually, there is a very slight different between models, that most often just entails a few extra features or decorative stitches.)
Hi, I have a PFAFF Hobby 420 sewing machine. Its motor is not working and there is no service centre of PFAFF in our city. Could you please guide me opening the motor??
Maybe it just needs new carbon brushes. My Bernina 830 Record resembles the Pfaff very closely. I had issues with the motor stuttering. Changed the carbon brushes and it runs like a top!
PFAFF Mail Repair Garry Machine
http://www.ebay.com/itm/Pfaff-Hobby-301-420-Serger-Overlock-Service-Repair-Manual-/171310126409
Why does the left needle thread on my pfaff coverlock 4862 break
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
3helpful
Threading
Mary - I sympathise with you regarding the "vague manual directions". I have a Pfaff 4862 and if I hadn't found the video, I would never have managed to get it working. There are animated videos at the Pfaff website, just not sure if they would still have them up for the older models - but worth a try, surely.
Power switch is broken on my pfaff creative 1473
yes you can order a new switch. once you have it just pay close attention to how the old switch was installed and install it the same way. be sure to have your machine unplugged while you do this repair.
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
