1st. remove the foot from the machine to give you working room.
2nd. get the long plate "throat plate" look at the under side, you will see 1 side the slide part crimp shut, this is the side that will be the front.
3rd. put the plate in place as it should be, then push it up thill it clear the metal clamp.
4th. use a screwdriver to lift the clamp metal so it fits into the grove of the plate, do this for both sides.
needle plate.
there is a fat stud and a small stud for the plate to fit in.
take the plate and slide it under the fat stud, it will lift as its spring loaded, push it all the way and then the small stud will fit into the other side
