Note its not the same as 84 thru 89.
You have to take off the passenger side knee bolster for the relay. From the trans tunnel to the door- Fog lamp relay-Courtesy Lamp Relay----Fuel Pump #1 Relay-Horn Relay-Rear Defogger Relay. Fuse is located in the Main Fuse Block Located on the right side of the dash (small panel pops off the far right side) passenger door needs to be open to do this. The fuse is labeled FP 1 and is the furthest fuse left on the second row from the bottom Red 10 amp. Fuel pump is located under the fuel door in the back of the car- you just need to take the door off and you can check for voltages or even replace the pump from there- no need to drop the tank or anything .
