But then stops at the rinse cycle and won't go any further. Spin cycle does works. Not sure if the problem is in the selector switch, temp switch, or the water inlet valves. Any help?
Sounds like you need a water inlet valve. The solenoid on the cold part of the valve isn't letting water in. And it stops at the rinse cycle and won't advance because the rinse cycle uses the cold water side only and if it dies not fill with cold water it will not advance. That will fix your problem
