Televison & Video Logo
Question about Toshiba Televison & Video
The input source button on my Toshiba TV model #19AV51U TV will not stop at the selected source. It quickly scrolls through each source several times without stopping when trying to select my desired source. It doesn't matter if I use the remote or the button on the TV. The same thing happens. Karen
Posted by Karen Sepulveda on
David Spradling
    Top Expert:
  • Toshiba Master
  • 13,317 Answers
Bad control board
Posted on Aug 19, 2022
Larry
  • Toshiba Master
  • 4,679 Answers
Hi Karen, it sounds like a bad button on the TV
Posted on Jul 07, 2022
  • Karen Sepulveda
    Karen Sepulveda Jul 07, 2022
    The same thing happens when I try and use the remote control to change the input.
  • Larry Jul 07, 2022
    If it does it with the remote it has to be a main board issue
Vizio TV Input Menu Scrolling
Have you got any other remotes in the room that could be faulty or interfering with the WDTV.
Also:
try resetting via the side button with the unit on.
resetting to factory defaults via the internet menu.
unplugging the unit from power for some minutes (not seconds).
Do all the above one after the other before using the WDTV.
Sometimes this helps particularity after a firmware update.
The input source of the TV can be changed either through the supplied TV remote or physical buttons located on the TV itself.
Changing input source using the supplied TV remote.
  1. Press the INPUT button on the supplied TV remote.
  2. The input source screen will be displayed on the screen of the TV.
  3. Using the arrow keys, choose one of the input sources on the input selection screen.
  4. Confirm the selection by pressing the Enter button.
Changing input source using the physical buttons on the TV.
  1. Press the INPUT button located at the back of the TV panel.
  2. The input source selection screen will be displayed.
  3. To scroll through the options, press the INPUT button repeatedly. The last highlighted option will be chosen after few seconds.
Can I change HDMI1 to HDMI2 or Video manually without the remote
On some TVs, you can change inputs by using a Source or Input button on the TV. These front panel buttons may be on the bottom of the TV bezel, on the right hand side or on the back on the right side as you face the TV. Once you locate the FPA buttons, you either press the Input button several times. Press the Select equivalent or just wait for the input to change. Alternatively, you need touse the Channel or Volume buttons (one pair becomes Up/Down, the other Left/Right) to navigate through the list. Then hit the button that gives the Select equivalent. A few models let you change inputs after pressing the Menu button on the TV and moving through the on-screen menu to a Source sub-menu. Not all TVs support this.
Please add a comment with the manufacturer and model of your TV for specifics that apply to your TV.
I hope this helps.
(Note: if you replace your remote control, check for a Source or Input button on the universal remote. Then try multiple codes for your TV brand to find a code that gives the input function properly.)
Our tv says 2-1 instead of hdmi.
Your television source has been changed to OTA and is tuning in the digital channel 2-1. Depending on the TV, there will be a source or input button on the original remote. You either press this button several times to change the source or you use the arrow keys to navigate through the list. You may need to press OK/Enter to confirm the selection. Some TVs also have a source/input button among the TV front panel buttons. Again you press the button several times or use the arrow key equivalents on the front panel to navigate through the list. On a few TVs, changing the source may be inside the on-screen menu. If you have a universal remote, it may match the source/input function. However, this depends on if the best code is programmed. (Some codes for a given brand don't match all of the functions for a given TV.)
Please add a comment with the make/model and the remote (if not the original remote) if you need help changing the source.
Why is (channel) scan option greyed out?
Often this happens when the input on the TV is not set to TV. Look for a Source or Input button on the TV or the remote. (If you are using a universal remote, you may need a different code to get this feature to work. Cheap universal remotes may not match the feature at all.) If there isn't a Source or Input button, you can check if there is a Menu item to change sources. On my TV, you press the Input button several times until TV is highlighted. Then press OK or simply wait and the TV will go to the new source.
Since this depends on the TV, please post a comment with the make and model of your TV for additional help.
I hope this gets you started.
Input source menu scrolls continously
I had this same issue, however it happened to be the HDMI cable that I used that was causing it, no idea why. I knew the cable didn't work well with my PS4 connected to the TV. But I used that same cable to connect my PC to the TV and the Input menu was going nuts. I disconnected the HDMI from the PC was still doing it, soon as I disconnected the HDMI from the TV it stopped. Just an FYI.
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
2answers
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, [email protected]
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
4helpful
6answers
Insignia is-lcdtv26 26", NO SIGNAL
This TV (Insignia) has been recalled (Model # : IS-LCDTV26) - Best Buy AS OF 04/02/2009 is STILL holding recalls for this TV due to fire hazards & power supply failure - the official report is here ->
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09183.html
Contact best buy's customer care hotline @ 800-233-0462 to get a gift card for upto $800 if you own this TV (Insignia - Model No. IS-LCDTV26)
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
