Question about Yamaha Audio Players & Recorders
HTR-3065 Firmware Update
Please let me know from where I can download the firmware update file for YAMAHA RECEIVER HTR-3065 Thank you
Posted by Shaju... on
ADMIN Eric
    Top Expert:
  • Yamaha Master
  • 37,742 Answers
Through an authorised Yamaha Electronics Service Centre.
They are not available to the public as firmware damage may occur and that will destroy your receiver.
Posted on Jul 07, 2022
What does error code 0010 mean on Yamaha av receiver Rx-v773
- Firmware update doesn't start or doesn't complete
? Receiver doesn't power up after the update.
? Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
- Error message appeared during the update
Cause: For some reason, the receiver can't read the firmware data.
Method: For your solution, check the following
[Update through Internet]
? Check Internet connection.
Check if the Internet connection is working by playing an Internet radio station.
(See owner's manual for details)
[Update by USB thumb drive]
? USB thumb drive is connected properly to the receiver.
? USB thumb drive is not password protected.
(AV receiver cannot read data from a security protected USB thumb drive)
? Make sure the USB thumb drive is inserted before the receiver is powered on for the update.
? The firmware data is stored in the root directory of the USB thumb drive.
? There is no other data except the firmware data in the USB thumb drive.
? No folders are created in the USB thumb drive.
Else, retry the update by USB using another USB thumb drive.
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
My HTR 3063 is not producing any sound
The YPAO isn't on the 3063 model. only 4063 and up. If this is used and you can't get your money back, there is a firmware file here http://download.yamaha.com/search/product/?language=en&site=ca.yamaha.com&product_id=1436250 that can help get your receiver running correctly.
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
2answers
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
No audio comes from the rear right speaker. what am i doing wrong with connecting the speaker on the htr-6130?
Swap the rear right speaker to rear left make sure the speakers and speakers wire are OK
Initializer the unit as follow set the unit in STBY mode if you are not sure which mode turn off the unit with the remote control now the unit is in STBY mode. Pressing STRAIGHT and AUDIO SELECT keys simultaneously then press power STBY button on front panel the display will show 1: Analog ByPass use the PROGRAM knob to move up to 13 PRESET INHI then press 1 or 2 keys to change to PRESET RSRV then turn off power now unit reset to factory just turn on and try it
Let me know how do you go
Cheers
PS: this model have an update firmware if your is still under warranty bring it back to Yamaha or 1 of the service center Yamaha they are able to update for you. Due to confidence I can not post that firmware sorry for that inconvenience
22helpful
4answers
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
