Refrigerators Logo
Question about Whirlpool Refrigerators
Change 40A15 bulb Whirlpool fridge freezer
Side-by-side freezer (icemaker/water). Can't see it. Model# ED2KVEXVQ01 in 2012
Posted by Bryan Webb on
Whirlpool side by side fridge. Everything freezing in fridge. cannot lower temp below 38. Icemaker affected with less water flow, small cubes falling through opening to produce ice
Check to see if the condenser is clean. If the coils are no free of debris, this will affect the fridge and the freezer temps. How old it it?
I have a GE Side by Side (model GSL22JFRJBS) and am having several problems and I'm not sure if they are connected or if I just have bad luck. 1st: the freezer and fridge are not staying cold. The freezer...
HI change the main board its about $150-200. Will fix all your problems except the lightbulb would be a lightsocket problem or the bulb you put in is bad, or door switch.
Sean
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
1helpful
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
New side by side with icemaker, no manual
Yes perfectly ok. Just remember to clean the ice maker area well befor you use it.
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
2answers
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
2answers
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Top Whirlpool Refrigerators Experts
Steve
David Shaub
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
