Heating & Cooling Logo
Question about Frigidaire Heating & Cooling
Frigidaire model fftr1835vs styrofoam inside filter housing unit. Should it be there?
Thomas Woodburn
  • Frigidaire Master
  • 2,638 Answers
Not 100%certain to what styrofoam you are referring to but there is definitely styrofoam components inside the machine. The entire drain pan is made of styrofoam, I would not touch it.
Posted on Jul 04, 2022
Testimonial: "Thank you. It's located right behind the control panel in the refrigerator. It's part of an optional filter housing unit."
  • Thomas Woodburn
    Thomas Woodburn Jul 04, 2022
    If it’s restricting air flow you can take it out but…
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
We have a frigidaire a/c wall unit with mold. Problem is the inside is styrofaom and scrubbing it will destroy the styrofoam How do I clean it??
Unplugg it , spray bleach on to effected area .wait till mold is gone then plugg back in. Make sure to Keep the filter clean
1helpful
I thought the styrofoam inside the dehumidifier float was packing material & threw it away. Now my dehumidifier gets too full before the "full" sensor comes on. Can I replace the styrofoam?
Hi Kim - I understand that you removed the styrofoam inside the dehumidifier float thinking it was packing material, however I would recommend contacting the manufacturer to verify if it the part is available and can be replaced.
1helpful
2answers
The styrofoam inside the unit is covered in black mold. I was wondering what i should do if anything.
Any mold in any part of the unit is not good, especially if its in the Styrofoam, Styrofoam has pores and hides the mold spores well, it would be dangerous to actually run the unit with mold spores as it can travel inside the house. Unfortunately companies that make these units don't make these units mold proof, why should they? that's how they make their money. I have three units, one has always given me problems with mold. It always comes back. The other two are always clean. My best advice, get rid of the unit and get another one or get a free estimate on Central air and heat. Mold is very dangerous and is not worth the risk, it can cause a number of medical issues.
5helpful
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
1helpful
4answers
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
6helpful
2answers
Frigidaire Air Conditioner - FAC102P1A Compact II th
I spoke with the Frigaire support line 706 374-4432. They said that the large piece of styrofoam, that extends from side to side and nearly top to bottom, is part of the unit. It should not be removed.
2answers
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Frigidaire Refrigerator - Model # FRS26ZSG
The housing is probably cracked due to it freezing.
Top Frigidaire Heating & Cooling Experts
Robert
David Shaub
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
