Realize???????
Testimonial: "RELS ... meaning release the door, like the 2 button was pressed and hold on the main unit, or on there remote station, however remote station are disconnected and button not pressed on the main unit"
The manual doesn't mention this, the word 'realize', are you sure?
https://www.manualslib.com/manual/799690/MAnds-Systems-Mc350a.html
You have an issue that no one else has encountered.
https://www.google.com/search?q=M%26S+350A%2C+display+shows+realize
didn't help remote station are disconnected
Unfortunately the question was just too vague. The new added part helps.
Replacement parts and repairs.
https://www.google.com/search?q=m%26s+35...
Sorry, RELS ... if I'm not wrong that means "door release" ... that is what supposed do happens when on the main unit you press and hold the "DOOR TALK" and "ROOM TALK" for 5 seconds ... so it release the door (case wired for that)
The problem is that all speaker are disconnected, so not short circuit on wiring causing that, also check the push buttons and they NOT "locked" to the end.
Also those 2 buttons don't works as they should ... it supposed when you press for example "DOOR TALK" it supposed to show in the display "TALK" and when you release it supposed to show "LIST" for 20 seconds
I already check the resistor on the button board and they are OK ... they have 10K what return 5v for the processor, and 5K and 22K and a diode which in combination with the push button drop the voltage to 1.6v , 3.4v and 0.5v depend on the combination of pressing ... it's like the main processor is not getting reference for this voltage ... the voltage from the buttons are there, I already checked on the processor board, according to the push button, but like the processor needs a reference and is not present.
