Not sure where you are but Repco sell conversion harnesses that suit a lot of different cars. I used one of these to put a new stereo into my Sons car and it worked perfectly. It matched up the Hyundai radio plug to the new Stereo. Cant remember which make of stereo. Give Repco a call. I think it was about $25 and saved a lot of grief.
scroll down the page to the owners manual link. It has the wiring in it. The 380 is the slightly older model but all the color codes of pioneer radios use the industry standard colors.
I hope you didn,t cut off your original factory radio harness, The easist way is to buy a wireing harness adapter kit.That hooks up to the wires on your new deck, End has plugs on it that plug into your factory radio harness. They can be braught at most places that sell end install car audio equipment for $15to $25 at the most.
Radio Constant 12V+ Wire: Orange Radio Switched 12V+ Wire: Yellow Radio Ground Wire: Black Radio Illumination Wire: Gray Radio Dimmer Wire: Brown Radio Power Antenna Trigger Wire: Pink Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 6 1/2′ Speakers Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Speakers Rear Speakers Location: Side Panels Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
Hope this info helps please let me know if you need any further info
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Yellow
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
pls rate because noone has been rating hope this helps
