This is a fully manual turntable, meaning, the tonearm will not engage a switch that powers up the unit. You have to turn it on. The power switch is towards the rear of the unit, on the top, right at the rear of the tonearm. You'll see a button. Press that button, and your unit should power up.
If it does not power up, then you have a faulty unit. If you bought this new, I would suggest returning it. If it is not new, then either you have a bad fuse, or burned out transformer. The fuse you can replace yourself, but the transformer requires a technician.
Hope this helps.
TWEAK AV LABThe ORIGINAL TURNTABLE Technicians.
