Refrigerators Logo
Question about Maytag Refrigerators
Maytag Side by Side RSW22EO Refidgerator Freezer , not cold enough.
I have a older Maytag (Model No. RSW22EO) Refrigerator/Freezer that uses "R-12 Refrigerant". 3 days ago I noticed it was not keeping things as cold as usual. I tried setting the temperature adjustments to their lowest setting and checked back 24 hours later, and while it did get the freezer to keep things somewhat frozen, both sides (fridge and freezer) are certainly not getting cold enough. I have not checked actual temperatures, ( as I don't have a thermometer), but it is obvious it is not working properly. I pulled the fridge away from the wall and checked to see if dust had excessively accumulated on the radiator and condenser, but since I blow it out yearly, there was very minimal dust accumulation. To my novice ears and eyes, the compressor and fan appear to be working properly, but I can only attest to compressor having a slight vibration and the fan is spinning, but of coarse, that does not meant they are actually functioning at peak performance. My guess is it is low on R-12 Refrigerant, which will require a professional with a EPA 602 license, not to mention limited availability and the ridiculous cost of R-12 refrigerant. If you have any suggestions on how to troubleshoot the problem, I would be very grateful. I have only a basic multi-meter for electrical testing, and I do not have any means or skill to test refrigerant levels. REPAIR PROCESS: Well, since no one had an answer, I thought I would give an update: well, the problem got progressively worse as the freeze was now unable to keep things frozen and the fridge side was not cold at all, so I decided to tear into the project and see what I could find. DISASSEMBLY: To gain access to the parts, I needed to get into the back of the freezer from inside of the freezer compartment. First I removed all the wire basket drawers from the freezer compartment, then I unscrewed the drawer guides from each side of the freezer's inner side walls (these are held in place with two 1/4 inch hex drive screws per rail), Next I removed the Ice maker's plastic bin (actually, I removed this years ago so I cannot recall how I got it out, but I think it just pulls out without any fasteners, but don't quote me on that). Located near the top of the freezer compartment's back wall is a rectangular housing that has the light and the ice maker's motor, this has to be removed as well. It is held in place by 6 stainless Phillips screws (2 on each side and two more along the top edge). Note, to be able to access these fasteners you will need to carefully remove the light's diffuser lens by slightly compressing it to get the tabs on the top and bottom edges to release from the slots (there are not any fasteners in the light lens, and also unscrew and remove the light bulb. Then you should be able to tilt forward/downward the light/motor housing and wiggle it out, but if you cannot get it to come out, you will likely need to remove the entire ice-maker and the panel above the housing we are trying to remove. I was able to get it out, so I did not remove any other parts thus far. Next there are 7 stainless Phillips screws holding in the main back panel (that covers up the condenser coils), 3 screws on each side and 1 centered at the top. Once the screws are removed, simply grab the panel at the top edge, lift it about an inch or two, and then pull it out towards the front, and set aside. DIAGNOSING: Well it became immediately apparent what the problem was, since both the upper and lower condenser coils were completely frozen and frosted over. It was not thawing out as it should. Near the top is a black round thermostat with two wire leads ( one white wire, one blue wire), so before defrosting the freezer, I unplugged the fridge from the wall outlet, and using a multi-meter i tested the thermostat for continuity between the wire leads. Note: this must be done when the temperature on the Thermostat is between 25 and 40 degrees Fahrenheit. If you cannot test it in the freezer, remove it and stick it in a different freezer before testing. Well, my thermostat was fried, but that was not the only problem... There are two heating elements (glass tubes with spring like heating coils sealed inside), which are located below each condenser coil. one is in the middle and the other is at the bottom just above the drain pan/funnel. Eack one is held in with two 1/4 inch hex drive screws. you may need to bend the metal on each side of the freezer to get the heater assemblies out. Prior to removal. you an test the continuity of the heating elements by tracing the thicker wires back to the jumper-board next to and to the right of the thermostat. Disconnect the spade connectors of these wires and test for continuity. My continuity test failed, so these need to be replaced also. Since these marts are useless, and the wiring connecting the heating elements was entrapped in the condenser coils, I just cut the wires and pulled them out. Upon further inspection, it was clear one of the coil-spring heating elements inside the glass tube had a beak in the middle, and each tube lost it;s seal allowing moisture to enter the glass tubes of the heating elements. I am awaiting parts, but once installed, I am confident the freezer will go into it's scheduled defrost cycles as expected, and all will be working as it should. The only other thing that could have failed would be the defrost timer, but I am not sure where that is or how to test it. I read it may be located behind the front grill below the doors, or it is inside the fridge side near the temperature controls. CONCLUSION: To be determined after I replace the failed parts.... .
Posted by KelMaster on
Maytag refrigerator model number rsw22eo having problem with freezer not defrosting
You have a=>68233-3 Defrost Timer mounted somewhere behind the kick plate at base next to floor. Can you turn the timer slowly clockwise until the compressor and fans stop? I want you to force the refrigerator into defrost. If after 30 minutes the refrigerator does not restart running again replace the defrost timer. Once you place the refrigerator into defrost the elements should melt the ice that has been building up. If placing the timer into defrost does not help you will need to replace the=> 61001846 Defrost Heater Assembly . I am here if you have questions, John Tripp Appliance 911
Contact me here.
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Freezer side will freeze but refidgerator side wont cool
heatman101
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
The food and drinks in the refrigerator does not feel and taste cold enough. The freezer is just fine.
Check for proper operation of the freezer fan. This fan moves cold air from the freezer to the refrigerator. If the fan is not turning, the freezer will be too cold and the refrigerator will not be cold enough.
The fan should be behind an access plate at the rear of the freezer. Listen for the sound of the fan. If you can't hear it, remove the cover and look at the fan. If it's not turning, you will need to replace the fan motor.
1helpful
2answers
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
hhkgjd
Refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
2helpful
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Open Questions:
Top Maytag Refrigerators Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
vince
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
