Motor overload in the air compressor ir
You have to twist the e-stop to reset it and once you’ve done this you still have to reset the fault by pressing the reset button on the controller. It looks like a red triangle inside a circle with a line through it and depending on how old your machine is, you may have to double-press the button. If this doesn’t fix it check the BLUE wires coming out of the estop going to the controller and make sure nothing is loose. If all this doesn’t fix it your estop button is probably broken.
