Cameras Logo
Question about Sony Cameras
Sony Handycam DCR-DVD 610 - Camera cannot use battery error even though battery is not plugged in the camera
I've had this camera for a couple of years now and ever since then the battery has completely died. I wanted to get the footage out of the memory stick in the camera since I had alot of good memories in there. When I wanted to put it on a tripod I accidently dropped it (small 8 inch fall I believe) and it shut off even though I had it plugged in to power, so I unplugged and plugged it back in then turned it on. The camera worked for 5 seconds untill an error saying "Cannot use battery in the camcorder." with error code "C:04:00" even though I had no battery in the camera and it was plugged in to power? Weird thing is that when I press the DISP/BATT INFO button it turns on and after 5 seconds it shows the same error from before (this does not happen when there is no battery in the camera). I've ran out of solutions to fix this and I've tried pressing the reset button and nothing worked. Anything helps!
john h
    Top Expert:
  • Sony Master
  • 28,844 Answers
You damaged a circuit send it in for repair
Posted on Jun 30, 2022
  • Anonymous Jun 30, 2022
    There isn't any stores that repair old cameras or tech near me, if possible could you tell me which circuit I broke? Because one year ago I've actually encountered this error once when I didn't have the battery in but after unplugging and plugging it decided to work properly.
ADMIN Andrew
    Top Expert:
  • Sony Master
  • 57,211 Answers
They need the batteries in them for all functions and generally there are two. One is the main battery that you recharge and can swap out if you do a lot of filming. The second one is a small coin cell that holds the memory when the main battery is removed. It is the same as the CMOS battery in a computer.
Both batteries need to be inside the Camcorder and charged.
https://www.google.com/search?q=Sony+Handycam+DCR-DVD+610
Posted on Jun 29, 2022
  • 2 more comments
  • Anonymous Jun 29, 2022
    I've had no batteries inside the camera and ran it thru the AC adapter with no problems aside from all of the settings getting reset when it loses all power from it being plugged in before.
    Although I am confused about the cell battery, does this camera have one? And if so is it possible to replace it inside?
  • ADMIN Andrew
    ADMIN Andrew Jun 29, 2022
    187 mentions of the word 'battery' in 159 pages of text, and there isn't one, or if there is, it is internal.
    I still think it needs the main battery. It says the battery in 'InfoLithium' and is proprietary to the camera. It communicates information to the camera. Or the fault is due to the drop.
    https://www.sony.com/electronics/support...
    I don't know, the camera has worked perfectly fine without the battery for quite a long time so might have been the fall.
    When it fell, it hit the power cord first and landed on the DVD cover. Maybe something around that side broke or got disconnected? I'll try finding a battery on AliExpress, but thanks for the help!
  • ADMIN Andrew
    ADMIN Andrew Jun 30, 2022
    You are very welcome. :>D
    Amazon for $19.00
    https://www.amazon.ca/Sony-DCR-DVD610-Ba...
    or 2 batteries and the charger, if you wanted to sell it on after you remove your videos.
    https://www.ebay.com/itm/274777988896?ha...
My Sony HandyCam DCR-DVD105 suddenly started shutting itself off after about 20 seconds. I have recharged the battery, and that has not helped the issue. the camera also will not open its disc access, even...
No problems, at last Sony have listened to camera users and heard that the models that use DVD are no good, so Sony along with most others have dropped the DVD models, they simply never were reliable enough.
Grab a Digital 8 tape camera from Sony if you feel you prefer no hasstle in movie making, most already have.
Sony handycam dvd92 battery warning light comes on even after battery is charged. bought new battery same problem
Yes the good old DVD camera, you like millions of others get this problem with that model, it is looking like DVD disk cameras have a 84% break-down problem, we need to get Sony to start to make proper cameras that use 8mm tape again, it is a media which does work well.
3helpful
Sony handycam dcr-dvd201e disc error c:13:00
You are using DVD+RW instead of DVD-RW. This camera does not support DVD+RW.
1helpful
2answers
Sony dvd DCR DVD 705 I am not able to finalize.
hello sir i have a problam . last night i shooted a video or some photos in a function.and when i come to home.the battery level is 10 min.then i want to finalize it.in meantime the battry is stopped and the handy cam is got shutdown.when i started the camera the finalize option is disabled.unfinalize option is disabled.when i want to format it shown data error.the computer could not read it.what should i do.i need that video must.help me.pls.model no.is Sony DCR-DVD705.
Recharge battery
Following picture might help you. its in instruction maunal page-20
Sony Handycam E:40:00 Error Help
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Camcoder not starting up
2answers
Sony error code
cheak batteries and the tape your using
Dcr-dvd 205 error code
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
