So I have an issue with my laptop where it doesnt boot up and just shows a black screen and i tried everything but it didnt work. So if anyone has a solution to this issue please help me (PS: If someone has the bios drivers for the laptop please send it as it would be soo helpful) Thanks!
Hp dv4-1430us, CCFL are all dead now.
no USB devices, nor CD tray full.
Rule #1 no 14 year old battery good here. ever.
the big one (drops out) and the coin cell are dead.
the latter can not be ignored dead ever. if you let it die BIOS GOES NUTS (mad) acts dead or lies to you.
BIOS needs a good coin cell, or goes to CHAOS.
end bad batteries now.
step 1 on all laptops on earth is, remove the big battery and see if it runs on AC power pack only (even forever if not mobile used)
so splash screen and bios is dead still.
step2
hold the power button down for 10 seconds and release.
screen works now,? if not do that 1 more time, 10 seconds and release. ok the screen is still dead.
so now point a flash light to the screen (dim room)
power on PC again same way do you see data now, yes,
'the CCFL lamps are dead. I assume the brightness key is UP.
Fn key.
there are 20 more parts to fail and cause this. (shorted)
the Nivida chip does not REMOVE ever and worse,, omg
NOR IS NVIDIA chip there at all, hark.!
Intel Graphics Media Accelerator (GMA) 4500MHD
only this is there, for Graphics.(video) period.
try?>
the vga port connected to video vga monitor will work(test)
hp sadly ended support on DV4-1000 series, only 3000 up.
if you need the 20 tests to find the other 20 causes ask.
even a bad AC power pack is one.or wrong one. (oops)
and lots of shorted modules inside.
I posted this 100 of times, on on HP DV PCs posted here.
and they are are all , mostly dead. 14 years old, CCFL are dead
and there is no NVIDIA here period!@
or a broken jack at PC rear, 19vdc jack cracked, inside or outside.
fails all tests, above.jack bad.
do not attempt to flash the bios on any sick PC like this dead.
you will brick it , do not listen to youtube kiddies.
tell how far you get and we can go farther. ask, for the steps.
6.jpg">
the simple answer on most DV PCs
is the screen is dead. there is no NVIDIA chips here. at all.
the GM45 chip has a GPU inside it for CORE 2. DUO cpu.
aka iGPU.
HP does no sell this part. no support it. (LCD +CCFL panels) at all old. 14years.
and scalpers sell it for $300 (screens)
the PC has zero value. now. dead.
unless CCFL can magically self heal, never
but yes, do the tests. luck happens, but so rare on DV .
