Sanyo Katana SCP-6600 Cellular Phone Logo
Posted on Aug 28, 2017
The screen on my phone is all black spots? Nothing works!!!
I flipped my phone open and got black spots and where there wasn't it was just white, with some random colors striped on the entire screen. now my phone is completely unusable and I don't know what to do. I have Kantana Eclipse from Sprint, and from what I know of it, it doesn't have a reset button. I have tried to remove the battery but that doesn't help either. PLEASE HELP!!!
Remus Monteron
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 28, 2017
Remus Monteron
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
169
Points
Usually the LCD screen is connected via flex ribbon wire. Either this needs replacement or the LCD itself.
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Mar 20, 2008
SOURCE: Sanyo Katana 1 - White screen
Yes- take the device to a Sprint store (thats who you actually talked to) and ask them to upgrade the software on your phone. This is a known issue and your firmware needs to be updated.
please rate solution. thanks.
Anonymous
  • 111 Answers
  • Posted on Sep 09, 2008
SOURCE: Phone was operating okay, now won't turn on.
good day ! i think the problem of you phone is the battery so you need to buy a new battery to work your phone again ! good luck ! thanks !...
A
Anonymous
  • Posted on Oct 15, 2008
SOURCE: Rescue Mode?
poo
Anonymous
  • 995 Answers
  • Posted on Mar 25, 2010
SOURCE: i have a katana eclipse x sprint sanyo
It so hard to operate a phone that has no display but you can have maybe your contacts by getting the sim card from your phone and transfer it to the other working phone.
Anonymous
  • 174 Answers
  • Posted on Apr 03, 2010
SOURCE: The Straight up and down phone on the first request it's not how my phone Looks!
type ##3282# then go down to advanced then click view, then lock code and it will display the 4 digit code
5helpful
My phone turns on but nothing comes up on the screen at all, its just black, i can still do things like get into the music so the phone is still working, but the sreen (display) is just black, i think i...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
1helpful
2answers
Whenever the phone is opened the screen is either white or shows just the wallpaper and nothing else.
hi :) your were flip phone,flip phone must have a ribbon inside. if it spoil,will made it no diaplay,speaker hearing pro and front display pro. so,your pro may the ribbon spoil already.pls send for technician for repair. Good Luck.
1helpful
My inside screen just says nokia and is all white
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
1helpful
Frozen motorla razor phone
most carrier retail stores have cellbrite machines and can retrieve your numbers so long as the phone powers on
2answers
I856 white screen
there is nothing wrong with your screen. The problem is from the screen flex. The flex is either worn out or has disconnected from its right position.
So you need to open the phone cover and check the flex. If the flex is well fixed and the screen is still displaying white, then it means you have to change the flex completely.
This kind of problem is common with flip and slide phone. Its as a result of constant opening and close of the slide or flip phone.
Take care.
The screen is all white and when i flip it open
just make sure that your phone is original and not a china phone!
1helpful
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
7helpful
BLACK SCREEN PROBLEM
it crapped out either the system software or the switch that recognizes when its flipped open -- shut the phone down.. crack it open a few centimeters so u can kinda see the screen i.e less than a 1/4 the way open , using a toothpick or something similar use that to press the power button, wait and the phone should load up. note allow it to completely load to the main screen and try to navigate the software while still in this position you may be able to flip it open to work it more comfortably but definately WRITE *pen/paper* your important info from the phone i.e #'s and ect.. and prepare to buy another phone
Screen problems
that mean your screen cable make lose or your screen mobile damage you must change it . when your mobile fill down this problem paper. :-(
Top Sanyo Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
 Mikey
Mikey
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
