Televison & Video Logo
Question about Pioneer Televison & Video
Pioneer remote stopped working for DVD player DV-490V. How do I reset it?
Posted by Adrian Cargill on
Steve Pack
  • Pioneer Master
  • 6,063 Answers
Have you replaced batteries in remote? perhaps remote is not working, you can buy a new one on amazon for $10.00
there is no rest.
Posted on Jun 23, 2022
Testimonial: "Replaced the batteries. This remote was a replacement (used), but I've only had it couple of years - was hoping to see if I missed something."
Hod do I factory reset my karaoke player
CAVS USA User Forum - H...
cavsusa.com/kb/index.php?action=sitemap&letter=H&lang=en
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
CAVS USA User Forum - W...
cavsusa.com/kb/index.php?action=sitemap&letter=W&lang=en
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ...
www.fixya.com > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
Acesonic DGX-109 USB Multi-Format Karaoke Player with ...
tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  1. Switch everything off.
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V Interlace Reset
tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 • Televison & Video
2answers
Can't play region 2 DVDs
You maybe able to get a region free code for your model player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Wanted remote for DV-220KV-K pioneer dvd player
Either try Pioneer or Google the model number with "remote" to see if you can locate one.
1helpful
Trying to reset dvd pioneer 270 out of progressive mode and nothing is working can hear sound but no picture
I just had that same problem with my Pioneer dvd player. I found the online manual for my dvd player. For restoring the default settings simply turn off your dvd player, then press the STOP button on the front panel of your dvd player while turning the dvd player on again.
1helpful
2answers
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
I need to manually reset my pioneer dv 490v to factory setting
http://www.pioneerelectronics.com/vgn/images/portal/cit_11221/310797959DV490VOperatingInstructions.pdf
to reset:
Resetting the player
Use this procedure to reset all the player’s
settings to the factory default.
1 Switch the player into standby.
2 Using the front panel buttons, hold
down the
(stop) button and press
STANDBY/ON to switch the player back
on.
All the player’s settings are now reset.
Cheers!
2answers
Region unlock code
Try this one
  • Turn On unit and remove any disc in the tray
  • Press the Setup button on the remote control.
  • Move over to General using the arrow keys
  • Select Basic
  • Press Display - this will display your region and firmware version.
  • Press Condition/Memory (nothing is displayed or changed on the screen)
  • Press the Region # required (i.e. 2 for Region 2 etc)
  • Press Menu to store
If you have no joy then you could visit the following web site
www.dvd365.net then click the option along the top \'UNLOCK\' then look up a similar model number.
Hope this helps you out. Please leave a thumbs up
Cheers
Little Dish Fitter
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
