I have already replaced the fan assembly in the back of the freezer. The error code in the front panel is E 1S or 15. It is a LG model LMXS30776s. Any suggestions?
If your LG refrigerator is only making ice when you open it up and push the inside button, and the complete fridge is not cooling well, there are a few things you can check:
As for the error code E 1S or 15, it indicates a problem with the ice maker fan. This fan is responsible for circulating air over the ice maker to prevent frost buildup. If the fan is not working properly, it can cause the ice maker to not make ice or make ice intermittently.
To fix the issue, you may need to replace the ice maker fan. It's recommended to have a professional technician perform this repair to ensure it's done correctly.
Also having this issue. Did you get it resolved?
