Pool & Spa Logo
j
jared azar Posted on Jun 21, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pentair MasterTemp250 thermostat showing temp of 126deg when pool is only 85deg. No error codes of any kind. What do I do?
David Spradling
Level 3:
Top Expert:
  • Pentair Master 13,520 Answers
  • Posted on Aug 06, 2022
David Spradling
Pentair Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
928144
Points
28384
What error code E01 indicate on a Pentair Mastertemp400 pool heater?
eo1 error code indicates temp sensor failure. Replace temp sensor. If problem persists then replace control board.
Pentair minimax NT pool water heater. Display shows no code violations. Heater does not come on.
check the roll out switch! or make sure your filters are clean if not those could be a flow switch!
2answers
What is pentair code ad0
ado is a code for stack flue temp set up if you look at a pentair chart you can find the procedure to change that
Error codes
You have a bad thermistor. The heater thinks that water temp is over 114 degrees.
Error code EO5
I am assuming that the manufature is Master Temp by Pentair. Is this correct? If so, the manual for it can be found here:
http://www.staritepool.com/pdfs/MasterTempOM.pdf
Aug 22, 2009 • Pool & Spa
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
