its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
One is a $20 mic and the other is a $30 mic. Both are "karaoke" mics. I can buy an AIWA DM-H100 Cardioid Microphone for $5 on eay and an Aiwa DM-H15 Cardioid Dynamic Microphone for $6.
You will need to unscrew the headshell (round mesh) and then remove the dynamic element and its damping rings (if any). Sometimes these are push-fit and you have to pull very hard to get it out, risking pulling the delicate wires out of the element. Sometimes there is a circlip or other securing mechanism which you will need to remove first. If you manage to get it open you will have to glue the switch back in place, using super glue or epoxy. Alternatively you could wedge the switch in place using a plastic/ rubber wedge.
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard, Your microphone usesthe following::
Pin1 ground (white)2 +ve or hot (red)3 -ve or return (black) Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on. The same connections can be veiwed in the user manual here Please rate this solution. Cheers regardsrobotek
