When I try to print it say, 0000.00 Exit, Ok, continue! What can I do to solve this problem?
The "warning no material" message on an Epson XP600 printer usually means that the printer is not detecting the paper or other media correctly. Here are a few steps you can try to resolve the issue: Make sure that the paper is loaded correctly. Check that the paper is aligned with the guides in the input tray and that it is not too thick or too thin for the printer. Check that the paper sensor is clean. Use a clean, dry cloth to wipe any dust or debris from the sensor. Reset the printer. Turn off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in and turn it on. Try a different paper type or size. If the printer is having trouble detecting a specific type of paper, try using a different type or size to see if the issue persists. Update the printer driver. Make sure that you have the latest driver for your printer installed on your computer. If none of these steps resolve the issue, it may be a hardware problem with the printer and you may need to contact Epson support for further assistance.
