Televison & Video Logo
Question about Toshiba Televison & Video
Toshiba DVR670KU DVD/VHS Combo Player how do I dub?
I got Verbatim disk dvd rws but I'm still getting an E25 message. Should I have the machine running through my cable box should I try just running it through the tv directly? or is it the RW thats screwing me up and I should be using just one copy disks?
Posted by Jeff M on
I just bought a magnavox DV225MG9 A player . The salesman said it could copy vhs tapes to dvd. how do I do this with this machine?
If this is the correct model number, magnavox DV225MG9, above, this unit is only a DVD player not a DVD recorder. It won't dub DVDs to VHS either.
I wish that I could be more help.
1helpful
Will not dub from VHS to DVD. I am getting an error message that says I have made a change with my video source.
You didn't give us a model number, always include this since it can have a big influence on the value of any response.
Missing this, we have to assume that you have a DVD player "Toshiba DVD Players"
This is how your message is labeled.
If this is the case, you never will record a DVD, only to VHS tapes.
1helpful
Hi. I have Toshiba sdv395 & was told I could dub VHS to DVD. There is no info in the manual. Can it be done & how. Roy
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
I hope this helps.
2answers
Tried dubbing VHS to DVDs, worked okay. But I cannot get the DVDs to play on my laptop. I used DVD-RWs. What kind of DVD do I have to use?
It depends on the specifications of the DVD drive in the laptop. Go to the website for you laptop manufacturer and look up the specifications. You also have to have DVD playing software. It is was not always included with the Windows operating system, although some kind of player may have been packaged with your computer when sold. DVD-RWs are recorded at slower speeds, which makes bigger dots and make not work with all DVD playback drives.
27helpful
2answers
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
