Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux washer always steams, even on cold setting
Hi - we have an electrolux EFLS627UTT washer. I have not selected the perfect steam option, and I am washing my clothes on cold; yet it constantly steams and shrinks my clothing. Any suggestions/advice? Thank you in advance!!!
Posted by June Heindel on
ADMIN Andrew
    Top Expert:
  • Electrolux Master
  • 53,131 Answers
Try disconnecting it from the mains supply overnight to reset. If it still does it, you need a service call. It is likely to be the Control Board and they are expensive so need correct diagnosis.
Posted on Jun 12, 2022
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
https://www.youtube.com/watch?v=uMFpFVOFE5M
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ...
www.city-data.com > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 • Dryers
Nothing happens when the 'Start Button' is pressed on Electrolux Front load washer
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
I ran the perfect steam option on my Electrolux dryer and ran the program but now the water continues to spray inside the dryer. How do I shut it off?
Thank you for your post, Travis!
I see that you are having a continuous spray of water inside of your Electrolux dryer from the Perfect Steam option. It appears that you could have an issue with your water valve or control panel. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If this does not correct your issue I would suggest having a professional technician for proper diagnosis and repair. This will help you avoid any future issues. Best of luck! -Matt
My lcd screen is faded and hard to read on my perfect steam Electrolux washer. Would like to fix this my self if some one can tell me how? Thanks
Thanks for your post, friend!
I interpret that you would like to change out LCD screen on your Frigidaire washer. Typically, this is not a simple DIY job. I would recommend consulting with a professional technician for proper replacement of such electrical components to avoid any future issues. If you would like to order the part you should reach out to the manufacturer for the proper part number and price. Hopefully this has been helpful. -Matt
1helpful
2answers
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner!
In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
I was drying my clothes and the steam feature would not turn off. How do I turn off the steam feature ?
Hi friend, thanks for your post!
I understand that the steam feature on your Electrolux dryer is not turning off. I would recommend a reset and you can do that by disconnecting power to your dryer for ten minutes. I hope this helps. -Matt
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Electrolux 12141 Washer/Dryer When opening the door the clothes are really steaming. We haven't noticed this before, the machine approx. 2 and a half years old. Is this normal? Or is it something that...
Your exhaust vent is blocked causing the steaming affect.
Remove the exhaust vent from the rear of the dryer and clean it thouroughly before replacing. Make sure it is straight as possible with no kinks.
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Open Questions:
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
