Computers & Internet Logo
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
I have DW60CDX2 ,It was working perfectly fine but last night it was showing E1, when I restarted today its buttons are not responding.Power button turns on but function are not working when i am pressing button Trying again and again but all in vain please help?
Roger R
  • Computers & ... Master
  • 2,005 Answers
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
Posted on Jun 07, 2022
2helpful
I have had a Hunter 52" fan with a Hunter Breeze remote that has worked perfectly for almost 4 years. Starting last night when I press the light "on" button, they flash on and off at the rate of about
Sounds like a loose wire nut to me. When you turn the light on the connection warms up and the wires will expand. When you turn it off they cool down and contract. Combine that with slight vibration from the fan over 4 years it could cause a loose connection. Just pull the trim ring down and tighten all the wire nuts. The light is usually the blue wire. Dont forget to kill the power first. If that doesnt work its probably a bad remote sensor.Inexpensive and easy to replace.
Dec 13, 2012 • Dryers
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
My itouch wont respond to me when i touch it.
my ipod touch (16gb) did the same thing. it has a large crack in the screen though. someone pushed me, and it fell out of my hands. for awhile it worked perfectly.. until it got froze onm that screen as well.
1helpful
Psp works slow
press the power button on your psp phat then press the r button triggerly and go to the cpu speed then press x button then default thats it
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
9helpful
2answers
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
3helpful
Dell Wireless Keyboard stopped responding, please help.
The keyboard should have a button underneath it. Press the button on the usb controller first and then the button on the keyboard. Repeat a few times to see if it connects. If you are still having trouble try another set of batteries as some batteries are not designed for wireless products.
2answers
Wont come on
try pressing one of the number keys instead of the power button on the remote
Marvin
Marvin
