Microwave Ovens Logo
Question about Panasonic Microwave Ovens
Microwave 8888 inPanasonic
My Panasonic microwave model number NN - SN766S is not working the window is flashing 8888
Posted by Carol Weiss on
  • Carol Weiss
    Carol Weiss May 30, 2022
    CAN'T DO THAT. IT WON'T WORK.
  • ADMIN Eric
    ADMIN Eric May 30, 2022
    If you cannot set the clock, the control board has a fault. Call an authorised Panasonic repair shop.
ADMIN Eric
    Top Expert:
  • Panasonic Master
  • 37,884 Answers
Set the clock.
Posted on May 29, 2022
Where in Canada BC I can buy Magetron for my Panasonic Microwave Madam Grill NN-8858?
The part number of the magnetron is on the magnetron label.
Beware, Lethal voltages are within microwave ovens.
Be warned!
1helpful
Where will I find the manual for the Panasonic microwave type s333 no, f00067602cp
Type S333 indicates something about the internal build; it's not the model number. Most Panasonic microwaves have a model number that starts with NN-S followed by 3 numbers and several letters. One microwave with the Type S333 on the serial number plate is the NN-S740BA. The manual for that is on the product support page: http://shop.panasonic.com/support-only/NN-S740BA.html . The direct link to the manual is ftp://ftp.panasonic.com/microwaveoven/om/nn-s740_mul_om.pdf .
Please check for the actual model number. Add a comment with that model number if you would like me to search for the manual.
I hope this helps.
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993.
Partstore.com has the owner's manual for sale: http://www.partstore.com/Model/Matsushita/Panasonic/NN2909.aspx ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. http://www.partstore.com/Part/Matsushita/Panasonic/NN2909/Matsushita/Panasonic/OMNN2909/New.aspx is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
2answers
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
1helpful
Inside light is burned out.
The Sears parts Web site has a ton of helpful info on this model, including disassrembly help. Looks like a lot of the actual service manual online! You can also order parts there. Enter your whole model number NN-S567BAS at http://www3.sears.com/ (the 3 is correct) Terrific!
Top Panasonic Microwave Ovens Experts
Jaime Hernandez
Paul Bade
Steve
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
