Question about Toshiba Televison & Video
The selections are grayed out and locked. I don't have antenna or cable & satellite. How do I unlock and select the HDMI.
Question edited for clarity.
This is generic help because you don't state the model. You have to do Link Setup first, then the options should become active.
Regza-Link Setup; Hdmi Settings - Toshiba Regza 32CV510U ...
https://www.manualslib.com > ... > Owner's manual
Using The Hdmi Settings Feature; Regza-Link Setup; Hdmi Settings - Toshiba Regza 32CV510U Owner's Manual ... and press T. ... Press B or b to highlight Enable REGZA ...
People also ask
How do you unlock HDMI on a Toshiba TV?
You may be able to turn the Panel Lock feature off by pressing the "Volume Down" button on the front of your TV for more than 10 seconds. Save your PIN code in a secure location where it is accessible only to you or other authorized persons.
How to Unlock Panel Lock on a Toshiba TV ' Techwalla
Posted on May 24, 2022
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
