the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem. In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
