Refrigerators Logo
wadingriver Posted on May 20, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chest freezer clicks on and off in a few seconds.
I have a Westinghouse chest freezer. It sat idle for a few years. I plugged it in the other day and it clicks on and off in about 4 seconds. I left it for a few hours and freezer was cold. Unplugged it again. Next day plugged it in to check reliability. Same relay sound but after a few hours, freezer was warm, compressor way hot. Replaced starter capacitor. Same issue, no cold. Did the compressor internals just give me one last cold then die? Not sure what it can be on these simple units. Manufactured in 1997
David Spradling
Level 3:
Top Expert:
  • Westinghouse Master 13,520 Answers
  • Posted on Sep 10, 2022
David Spradling
Westinghouse Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
927957
Points
28384
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    My Magic Chef 5.5 cubic chest freezer with manual defrost, just quit working. It was a year old this March and it stopped working this July. The power light is on, but run light is not. We unplugged for 5...
    Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
    My whirlpool freezer sat for a year and now I can't get it to turn n. Any ideas?
    it is either your thermostat or the overload relay. if it make a loud clicking noise every few minutes than that means it is your overload relay with is on your compressor but if not the it will be your thermostat. try tapping on it.but most likely it will need to be replaced
    Chest freezer lid wont stay open without holding it open, its a Westinghouse 25 to 30 years, is there any adjustment that would solve the problem?
    the hinges are bad and need to be replace
    go to sears.com and click on the parts link
    there enter the complete model number or call them if you want 1-800-252-1698
    check to see if hinges are still available
    hope this was helpful
    Kenmore chest freezer wont cool
    Hi.
    Here is a tip that will help you...
    There are also more tips at the bottom of this one...
    http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
    heatman101
    Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then quits....it then repeats this cycle. It was on its side when delivered
    Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
    Problem with Maytag Chest Freezer model MQC1557aew.
    First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
    3answers
    Kenmore chest freezer not working
    Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
    Top Westinghouse Refrigerators Experts
    vince
    john h
    Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
